Re: Re: Super-A brake pedal - wobbles on shaft
Posted by Kendall on September 06, 2000 at 13:37:29 from (207.136.59.189):
In Reply to: Re: Super-A brake pedal - wobbles on shaft posted by hendrik on September 06, 2000 at 13:04:53:
I just returned from the machine shop and the guy said it looks like the shaft is "mushroomed" on like a rivit would be and if I grind down the edge of the shaft and heat the outside, It should come apart. Since the pin is screwed into the shaft, it wont matter about grinding down the head. If I can get it apart I can mill it smooth and insert a bushing to fix the problem. I know some of this may not make sense, but if you ever take the break pedal off, you'll say OOOHHH! I SEE! If I ever get it fixed, I'll post what it took to do it.
Post A Followup
: Re: Re: Re: Super-A brake pedal - wobbles on shaft
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
