Re: farmall cub no start
Posted by screwstick on January 09, 2012 at 08:28:05 from (174.24.15.42):
In Reply to: farmall cub no start posted by jeep258goat on January 09, 2012 at 06:05:50:
Remove the #1 spark plug and with your thumb over the hole, rotate the pulley till you feel the pressure (compression) building up and continue to rotate the pulley till the you reach the second timing mark. You will now have the #1 cylinder TDC on the compression stroke. With this set, look over to the distributor rotor button, it should be pointing to the #1 tower, or about 1 or 2 o'clock.
