Re: farmall cub no start
Posted by El Toro on January 09, 2012 at 10:56:41 from (108.3.225.57):
In Reply to: farmall cub no start posted by jeep258goat on January 09, 2012 at 06:05:50:
There should be a metal strip that goes out to one side of the rotor and that end comes in contact with the buttons inside the cap. That's the end of the rotor that needs to be at 2 o'clock when you're at TDC on the compression stroke. Pour one teaspoon of gas in one of the plug holes and after replacing the sparkplug see if the engine fires like it may start. If the engine runs or makes an attempt to run you're probably not getting gas into the engine.
Hold your hand over the throat of the carburetor and see there's good suction when a helper makes an attempt to start the engine. Low suction means low intake manifold vacuum. Hal
