Posted by screwstick on January 09, 2012 at 12:11:57 from (174.24.15.42):
In Reply to: farmall cub no start posted by jeep258goat on January 09, 2012 at 06:05:50:
If the timing marks are not visible, with the #1 plug removed and after you have felt the pressure with your thumb, insert a screwdriver in the hole and let it rest on top of the piston. As you turn the pulley, the screwdriver will rise to the point of TDC and then start to drop. At the peak of the movement is where you would then check to make sure that the rotor is pointing at the #1 tower.
Edit: if you have low manifold vacuum, then you either have stuck valves (extreme case) or leaking manifold gaskets
This post was edited by screwstick at 12:14:02 01/09/12.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
