Re: One Row Cotton Picker Model Idenification
Posted by rustcollector on January 10, 2012 at 17:04:40 from (67.142.161.28):
In Reply to: Re: One Row Cotton Picker Model Idenification posted by Harold H on January 10, 2012 at 15:57:11:
Harold H,
There were 28 H-10-H built 1941-1943 rounded basket corners and cast iron header top with Madison Kipp oiler and mounted on an H Farmall. There were 41 M-10-H pickers that were the same as H-10-H built from 1943 & 1944 except on an M. The M-11-H was built (65) in 1946 and was basically the same as the M-10-H and still had a cast iron cover over the header and rounded corner basket. Other than a few experimental row units the aluminum cast cover began with the M-12-H(first aluminum cast cover built in 1943 and tested at Hopson Plantation in Clarksdale, then removed and replaced with a cast iron cover). This picker was the first with angle iron corners in the basket and the first with an oil tank for lubrication without the Madison Kipp oiler.
