Farmall 450 Gas Radiator repairs needed
Posted by Tony_Idaho on January 10, 2012 at 18:02:55 from (184.99.117.253):
third party image
third party image
Well, I found out what happens when you have too long a bolt just above the radiator and then start screwing it in. While tearing the tractor apart, I also found that the brace on the side seems to have come apart from the radiator
My basic questions are:
1. The color of the radiator is gold'ish, is that Copper or Brass or something completely different?
2. I was going to use an oxygen/acetylene torch to heat it up and Braze it. What type of rod do I need for the brazing.
3. Is that the best way to fix the puncture?
4. Can I use the same rod to braze/solder the side back together? There is no leak there, it just came apart.
Thanks for any information on this.
