Re: Farmall 450 Gas Radiator repairs needed
Posted by Ellis Kinney on January 11, 2012 at 06:03:08 from (74.130.194.205):
In Reply to: Farmall 450 Gas Radiator repairs needed posted by Tony_Idaho on January 10, 2012 at 18:02:55:
A brass patch piece, preferably about one sixteenth in thickness cut to size. Clean by sanding with emory paper. Treat with flux. Use Kester's 40/60 acid core solder. Mapp gas should be hot enough. This is not a difficult process, you should be fine. Remember, the torch should not melt the solder, the metal you are soldering should melt the solder when you move the torch away and touch the solder to the radiator. Ellis
