Re: Re: Steering loose on Farmall M
Posted by Andy Martin on September 06, 2000 at 20:41:49 from (38.31.74.137):
In Reply to: Re: Steering loose on Farmall M posted by Haas on September 06, 2000 at 17:13:26:
If everything is OK up top, look at where the shaft exits the tractor under the frame. The lower bearing may be loose and will cause sloppy steering, on wide fronts especially.
Have someone wiggle the steering wheel in it's free travel and see if the shaft is moving side to side.
Post A Followup
: Re: Re: Re: Steering loose on Farmall M
