Re: Cracked Block, 400D
Posted by Mike1972chev on January 13, 2012 at 08:20:11 from (75.149.81.173):
In Reply to: Cracked Block, 400D posted by 400D Guy on January 13, 2012 at 07:07:11:
Is there any water around the areas of the crack??? (Dont know if the block is wet in between cylinders on these ?????)
If not,chances are that NEW sleeve would me MORE stable than the original area of the block is.
