Re: Cracked Block, 400D
Posted by 400D Guy on January 13, 2012 at 12:55:39 from (69.76.146.214):
In Reply to: Cracked Block, 400D posted by scotc on January 13, 2012 at 07:07:11:
Yes, the water was leaking past the sleeve and into the pan. It wasn't more than a drop or two every several hours. After running it about 8 hours, cracking the drain plug would get me about 1/2 teaspoon of antifreeze.
It's a dry sleeve, but I had one that you might say was wet. The machine shop foreman assured me that boring, sleeving and sealing, then installing the cylinder sleeve would do the trick. I told him to proceed.
