h charging help
Posted by pete_5959 on January 15, 2012 at 09:27:03 from (24.74.204.42):
I have follwed Jonh T's procedure and have the following..I had the genny tested and it is fine. It does not have the asjustable third brush it is stationary. With the field grounded output of genny is 1.2v. As soon as I momentarily jump gen and bat on reg it goes to 10.3 v. When ground removed from field it drops back to 8.2v...I am using a healthy 8v battery. If i shut the tractor off I need to follow same routine. Is this a bad regulator? Thank you.
