Re: 44 H, hyd lever position ?
Posted by soundguy on January 17, 2012 at 21:27:04 from (184.4.159.217):
In Reply to: Re: 44 H, hyd lever position ? posted by Janicholson on January 17, 2012 at 18:33:26:
thanks!
this machine looks to be in much better condition than my C was.
I've already addressed leaks, and have fluids for changes and filters. will take a look at electrics on friday morning when I unload her.
tires are rough but hold air.
weights are un attached but looks like I have what is needed to hang them.. including a shop crane to lift those succers. they weight mor e than I do.. :)
as always.. thanks for all the help and hand holding.
i'm likeing the red side... machine feels -QUITE- powerfull.. takes throttle good. no smoking.
does like a bit of choke right after start.. but thent he C does as well.
muffler barks good.. is rusted out pipe at base..
