cub shift fork
Posted by Chief 83 on January 21, 2012 at 17:14:56 from (24.21.76.219):
I have a broken R/1 shift fork. I was able to get the 2 small broken pieces out of the trans but the larger chunk is still in there. It appears that you must remove the shift rail (not sure that is what it is called) to get the broken fork out and new one in. Thus a split is necessary. Before I do that I want to double check to assure that is the case or by some stroke of luck is there an easy way to change that fork?
