1955 300u Hydraulic pump noise and slow moving cylinders
Posted by windhillfarmer on January 21, 2012 at 18:03:09 from (50.39.155.78):
my 1955 300u has front end loader it make noise like sucking air for half a second after i move any function up down dump tilt back or up down fast hitch or if i rev up engine it also seem like there air in hyd. cylinders my loader has up power only single acting lift cylinders.the steel hyd pipes that run from pump to tank has a crack on the small pipe ive had it braze welded 3 times it all ways brakes i would like to buy non-broke pipes thanks
