There are only salvage pipes available It is certainly OK to adapt the steel pipes to Suction and pressure hose to make it work well. The suction tube is probably cracked or has a leaking gasket letting air into the system. Replacing the section of damaged steel line is also OK if the welds are certifiable, and as good or better than original. I would have the manifold plate at the pump drilled and tapped for fittings to allow rubber hoses to be utilized. I believe 3000psi hose on the pressure side and suction hose on the intake side are fine. Jim
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
