Re: WD-9 Belt Drive Shaft Seal
Posted by WD9ER on January 21, 2012 at 21:11:45 from (208.107.82.47):
In Reply to: WD-9 Belt Drive Shaft Seal posted by Janicholson on January 21, 2012 at 19:06:01:
I have the all the bolts out and the gearbox removed from the tractor. I am not sure it was necessary to remove it.
