Re: WD-9 Belt Drive Shaft Seal
Posted by plow hand on January 22, 2012 at 05:29:52 from (67.6.64.25):
In Reply to: Re: WD-9 Belt Drive Shaft Seal posted by WD9ER on January 21, 2012 at 21:11:45:
You did not have to do that...When you put whole
unit back in make sure you put the longest bolt in
in the casting...Because you wont be able to get it
in after unit is set in place....bolt will hit fuel
tank..
