Re: more on 1568 TA
Posted by RickB. on September 08, 2000 at 11:42:38 from (205.231.149.33):
In Reply to: more on 1568 TA posted by David Saville on September 08, 2000 at 09:37:34:
You need to look into the adjustment of the dump valve, which is operated by the clutch pedal. It sounds as if it is not bottoming out (closing) when the clutch is engaged. A partially open dump valve will cause a loss of drive pressure, and allow very little lube pressure, hence the light. The tractor is driving in TA mode via the sprag when the light is lit. Try lengthening the linkage going to the valve, sorry I can't be more specific, but that is surely the problem, especially if stroking the clutch intermittently cures it.
Post A Followup
: Re: Re: more on 1568 TA
