Re: Re: more on 1568 TA
Posted by the tractor vet on September 08, 2000 at 18:07:50 from (216.196.14.28):
In Reply to: Re: more on 1568 TA posted by RickB. on September 08, 2000 at 11:42:38:
check the hdy. filter make sure that you have good flow to the mcv. install a pressure gauge of atleast 600 psi in the bottom plug or the line that goes to your clutch hdy. asst. the pressure should be 235 to 250 psi.do a clutch adj. adjust the trans. brake then have someone help you set the dump valve in this manner . with trans. in netural and park lock set start the engine back off the dump valve bolt then push the clutch pedel down to the stop and start turning the bolt in till the lite just goes out stop engine then ad one more turn to the bolt lock it down then tryit and see what happens
Post A Followup
: Re: Re: Re: more on 1568 TA
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
