Re: Farmall cub (1950) Hydraulic pump
Posted by James Dean on September 08, 2000 at 18:28:44 from (209.244.85.230):
In Reply to: Farmall cub (1950) Hydraulic pump posted by Shannon Robinson on September 08, 2000 at 18:11:14:
Your pump may be ok.Some pumps have an oring and some have a lip seal.Both are dealer items. Remove your pump,pull the gear off-take the pump apart,pull the shaft out and see what type seal yo have.
Post A Followup
: Re: Re: Farmall cub (1950) Hydraulic pump
