Farmall cub (1950) Hydraulic pump
Posted by Shannon Robinson on September 08, 2000 at 18:11:14 from (64.196.18.247):
Just wondering if anybody out there knows where to get the specs on the hydraulic pump for a 1950 Farmall cub. Mine is leaking fluid into the crankcase. The cylinder completely empties within 24 hours and then I have to put the fluid back in. I can't see it leaking anywhere outside, so I know it has to be leaking into the crankcase. Does anybody know where to get the seal, (is it just one seal?). Also how difficult is it?
Post A Followup
: Re: Farmall cub (1950) Hydraulic pump
