Re: Super MD, removing frame rails
Posted by Bob M on January 25, 2012 at 08:30:13 from (67.240.168.45):
In Reply to: Super MD, removing frame rails posted by Dalrymple on January 25, 2012 at 06:38:31:
You can safely support the front of the torque tube (ie under the clutch housing). The front end and frame rails can then be removed leaving the engine cantilevered out front.
SAFETY FIRST! Be sure the both rear wheels are securely chocked, and you have a stable housing support beneath the clutch housing working on the tractor. (I use a crib of stacked 6x6 oak timbers)
This post was edited by Bob M at 08:33:08 01/25/12.
