Super MD, removing frame rails
Posted by Dalrymple on January 25, 2012 at 06:38:31 from (65.13.230.104):
Can I remove both frame rails at the same time while leaving the engine attached to the tractor and supported from underneath? If so, where should I support it? Oil pan? Torque tube?
I have equipment to handle the bolster and will separate it from the rails first.
