Re: What should I expect from my A
Posted by jbp on January 28, 2012 at 18:04:39 from (64.57.160.21):
In Reply to: What should I expect from my A posted by Machine249 on January 28, 2012 at 13:35:25:
It should have quite a bit more power at the same RPMs because of more cubic inches displacment and compression ratio. It will be about 42% faster in every gear as an A is governed at 1400 RPMs, the 240 engine is governed at 2000 RPMs wide open. You will have the fastest A in the neighborhood so be careful.
Joe
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
