Re: Re: Farmall cub (1950) Hydraulic pump
Posted by Garnet Best on September 09, 2000 at 17:10:11 from (142.177.81.92):
In Reply to: Re: Farmall cub (1950) Hydraulic pump posted by gene b on September 08, 2000 at 18:54:31:
Nearest IH dealer can get you an overhaul kit for the pump at reasonable cost. Has been a couple of years since I got one but think it was under $20. Included all O rings, gaskets, etc. and instructions and was better than "almost fit" solutions.
Post A Followup
: Re: Re: Re: Farmall cub (1950) Hydraulic pump
