Re: Farmall cub (1950) Hydraulic pump
Posted by gene b on September 08, 2000 at 18:54:31 from (63.25.166.33):
In Reply to: Farmall cub (1950) Hydraulic pump posted by Shannon Robinson on September 08, 2000 at 18:11:14:
any parts store should be able to get one about 4 bucks the o-rings are cheaper check the shaft if the seal journal is worn a sleeve can be pressed on they are only a few thousands thick then you have a new surface for the seal have done that works good
Post A Followup
: Re: Re: Farmall cub (1950) Hydraulic pump
