Re: Farmall cub (1950) Hydraulic pump
Posted by Bama Binder on September 09, 2000 at 17:36:58 from (63.10.118.170):
In Reply to: Farmall cub (1950) Hydraulic pump posted by Shannon Robinson on September 08, 2000 at 18:11:14:
Shannon...if the seal between the engine block and pump block is bad, the Hy tran goes into the crankcase...if your crankcase is over full that gasket needs to be replaced...if your crankcase oil doesn't go up when your hydraulics go down, you need to rebuild the hydraulic unit...Regards...BB
Post A Followup
: Re: Re: Farmall cub (1950) Hydraulic pump
