Farmall A starts hard
Posted by dahlin on February 04, 2012 at 13:47:08 from (184.158.16.185):
We have a 1940 Farmall A I've had it for about a year and a half. We put on a new carburator, new plugs and plug wires. Had the magneto off and cleaned and checked. It checked out fine. The tractor when it's cold won't start. Wants its started and warm if you shut it off it will start right up again. When you drive it down the road it has good power and does not miss a beat. I did a compression test with the engine at operating temp and all four cylinders tested out to be 90 PSI. I then did a wet test and the results were just about the same. I'm stumped as what could be the problem. Need HELP!!! Thanks for your help. Randy
