Re: Farmall A starts hard
Posted by gene bender on February 06, 2012 at 07:58:18 from (67.55.226.231):
In Reply to: Farmall A starts hard posted by dahlin on February 04, 2012 at 13:47:08:
You need to remove the cap on the mag and turn the engine over with a crank to see if the rotor is pointed on the tower when it fires. Just make a mark on the body of the mag where the tower is then remove the cap and you can see if the rotor is lined up on the mark when it fires. There are timing gears for the rotor and if you are off even a tooth it will make it hard to start. I have 7 with mags and they will fire rite upwarm or cold.
