Re: Firing Order stamped on block should mean?
Posted by Greg K on February 04, 2012 at 16:07:07 from (75.107.96.58):
In Reply to: Firing Order stamped on block should mean? posted by fort steele tractors on February 04, 2012 at 15:57:55:
If I understand your question correctly, #1 cylinder should be next to the radiator, next is 2 with #4 being the closest to the seat. The firing order is which plug wire in order goes where. Cylinder #1 fires first, then #3, then #4 then #2, then #1 again and so on. The trick is finding out where #1 is on the distributor cap. Sometimes it is stamped on it, and sometimes you need to pull the #1 spark plug and with a long piece of wire to stick in the cylinder slowly turn over the motor until #1 cylinder is on top. Then pulll the cap off of your distributor and see which terminal the rotor is pointed at. This will be a 50% chance yoU are right, if it will not run or runs very badly then change all plug wires with the one on the opposite side of the cap and this should remedy this.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
