Firing Order stamped on block should mean?
Posted by fort steele tractors on February 04, 2012 at 15:57:55 from (209.121.225.230):
Might be a stupied question but I am guessing the firing order stamped into the block of my B414 tractor which is 1342 with 1 being at the battry/gas tank and 2 being at the radiator. I was told 1 was at the radiator but the block is marked out as such.
If i go in a circle starting with #1 at TDC at the gastank end of tractor I should then work counter clockwise with number 2 coming from the front of tractor(rad) number 3 comming from the middle closer to (tank) and number 4 comming from the middle closer to the (rad)
Does this sound correct or am I missing something??
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
