Farmall H water pump repair
Posted by dcpky on February 05, 2012 at 09:09:43 from (67.142.170.26):
Took water pump off when went to digging old packing out was;nt much in there. I pulled back seal out then front seal taped out back bearing then tapped out front bearing the back bearing was bad. ? do i put back the way i took out bearings first then seals then put back together thn slide packing grease first then tighten nut? never rebuilt one before any info would be great Also there is a dust seal that sits down in water pump front side do i replace that All i got from dealer is two seals to bearings two pks of packing Thanks for all the help
