Re: Farmall H water pump repair
Posted by Kevin Meier on February 07, 2012 at 14:46:40 from (174.253.138.230):
In Reply to: Farmall H water pump repair posted by dcpky on February 05, 2012 at 09:09:43:
Put the beqrings and oil seals back in the same way they came out. You should have a machine shop true up the impeller mating surfaces. Packing will be the last thing you put in. There should be enough packing to put tension on the shaft and the packing nut will clear the t-bar but still have room to compress the packing more if needed.
