H transmission noise
Posted by Chester5731 on February 06, 2012 at 17:44:33 from (66.84.120.81):
The input seal to the trans on my H was leaking severely. I changed the seal and the bearing behind it because the bearing was worn. I also changed the seal for the lift all pump drive and the gear lube. When I drove it tonight the left brake would chatter but worked. There is also a chattering type noise is 2nd 3rd and 4th gear. 1st and reverse are ok and I did not try 5th. Any suggestions? I did not touch the brakes. I have never been in the trans on any of the old farmalls so I am confused. When the trans made noise I could feel a little vibration in the seat.
