Re: H transmission noise
Posted by Chester5731 on February 10, 2012 at 07:10:17 from (75.144.92.98):
In Reply to: H transmission noise posted by Chester5731 on February 06, 2012 at 17:44:33:
Bob, you are exactly right. I ended up taking the cover off. There are a lot of oil leaks that will get fixed also. Anyways, I noticed the splined shaft moved up and down a lot so I started fishing with the magnet and found six little rollers. The seals by the brakes are also leaking and the lining are all wet. I have ordered a bunch of gaskets, seals and a bearing. That little bearing is $88.00 from the dealer but I don't want to take it apart the third time so I am going to spend the long dollar on that one. It is quit a learning experience as I have never been in the trans of one of the old tractors before. Hopefully it will be good for another 69 years when I get done.
