Re: Replacing flywheel ring gear Chapter 2
Posted by sflem849 on February 08, 2012 at 16:17:13 from (69.197.84.39):
In Reply to: Replacing flywheel ring gear Chapter 2 posted by DC Snider on February 08, 2012 at 16:06:41:
It is like 8 bolts. Just take it off. There are 4 on the pressure plate and 4 to hold the flywheel on. I would be checking the PP for warpage and the clutch disc for wear anyhow. I might just put a clutch in it since they aren't really outrageous. I would also be looking for signs of the rear main seal leaking.
To get the old one off start a cut with the die grinder and whack it with a cold chisel. I have never done it, but I hear it works.
