Re: Replacing flywheel ring gear Chapter 2
Posted by Mike1972chev on February 08, 2012 at 16:50:27 from (99.14.210.136):
In Reply to: Re: Replacing flywheel ring gear Chapter 2 posted by sflem849 on February 08, 2012 at 16:17:13:
It does work.
If you score it witha small cut off wheel in a low spot in between the teeth and smack it with a BIG chisel and hammer,it will "give up".
