Re: 706 hydro levers
Posted by IaGary on February 09, 2012 at 03:37:47 from (108.160.229.48):
In Reply to: 706 hydro levers posted by morris roessler on February 08, 2012 at 22:03:37:
The Draft Control lever must be gummed up and stuck. It should move without doing anything else.
Start spraying some type of lube where it goes thru the casting.
Gary
