Re: 706 hydro levers
Posted by steve706 on February 09, 2012 at 06:50:27 from (216.208.94.112):
In Reply to: 706 hydro levers posted by morris roessler on February 08, 2012 at 22:03:37:
When I bought my 706 I had the exact same problem. There is a nut on the shaft the load control arm is attached to that you can loosen. On the shaft is friction washers that could be frozen, so just hose down with lube and gradually it should work free. I sprayed and worked it for about 3 days and it's never given me a problem since. With the load lever working you'll find you can control the hitch at any speed you need.
