Re: IH 574 shifting into 4th gear problem
Posted by Kippster on February 09, 2012 at 06:57:54 from (24.144.199.148):
In Reply to: IH 574 shifting into 4th gear problem posted by From Apto on February 07, 2012 at 15:11:01:
4th gear is synchronized. Try giving the lever a
little "twist" as you shift into 4th gear also back
the rpms down as you shift. Sometimes double
clutching helps. We has a 574 that I used to haul
silage wagons with. Lotsa road miles, so I got the
hang of shifting that ol girl pretty well.
