M head
Posted by BUCK CLAYTON on February 10, 2012 at 08:41:33 from (68.13.254.200):
The head needed to be shaved when rebuilding with all new valves. Problem now, the rocker arm adjustment ball will not screw up enough to get on some push rods and if you get them on they hold valve open just a little.No telling how many times head shaved down thru years. What can I do? Thanks for help. Buck
