Tuning C
Posted by FC on September 11, 2000 at 05:17:06 from (63.80.243.2):
I need input on the best method of setting points and timing my C. Think I finally got the carb problems worked out. Changed dist cap/rotor, (no mag on this one) found points burned slightly, filed and set at .020, runs fine at idle, but erratic at higher speeds. I think I should change points/cond and reset timing. Best method?? Is .020 best point gap?? I have a timing light, but never used on this setup. Thanks
Post A Followup
: Re: Tuning C
