Re: Farmall 560 injection pump bad ?
Posted by Aces on February 11, 2012 at 16:11:53 from (66.172.223.13):
In Reply to: Farmall 560 injection pump bad ? posted by Andrew Psencik on February 11, 2012 at 14:49:33:
Andrew You never said a thing about glow plugs. They will not start with using the glow plugs. Not supose to!!!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
