Posted by Jason Hubner on February 11, 2012 at 18:07:51 from (64.9.127.207):
The air cleaner filter material on my farmall 504 diesel is clogged up really bad so i got some new filter material. But the air cleaner does not seem to dismantal enough to allow for easy changing of the filter material. I have to pull the old stuff out the bottom through the holes. there has got to be a easier way. Or was it not meant to be taken apart? should i have soaked and rinsed the air cleaner in diesel fuel to dissolve the sludge? Thanks.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
