Re: replacing Air cleaner filter material
Posted by pete 23 on February 12, 2012 at 11:25:01 from (74.32.238.142):
In Reply to: replacing Air cleaner filter material posted by Jason Hubner on February 11, 2012 at 18:07:51:
Well, here is the problem with power washing, steam cleaning and all the rest. If the air cleaner has plugged enough to cause channeling along the edges which they often do, there is no way you can get that crap out from the top end. Around these parts, corn silks and chaff are the worst to try to get out. Granted, silks won't damage engine if they get through but when it gets enough it restricts air flow. Dirt will gradually work it's way into the engine if you only loosen it up and don't get it out. I have spent a lot of time washing these old girls over the years and when it still weights a ton you just give up and take it apart.
