They can very well be from the same tractor, no problem and you can install either kind back in those valves. What I am saying is that the detent mechanism itself is rated for different pressure detent settings. In other words, the old 1600 psi 706 you set to trip at below that pressure and the 2500 psi 1566 was set higher so they had to change the detent to accomodate that setting. The bottom detent has the o-ring right inside on the threaded end and is held in with a driven in metal cup . By detent settings I mean you pull lever , it stays and when system reached preset pressure it trips back to neutral. Actually, I think a lot of guys are just holding the valves until they get cyl where they want because those detents were not all that great.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
