the max clearance is .003 on the rod and mains. you already have .004 clearance with .002 under. brgs. that is telling you the crank is already worn out of round.. so its either o/h time or leave alone depending on your tractor usage. can use #40 oil or 20-50 to help the situation. just for example if you put the .002 under brgs.brgs in the engine with no wear you would not even be able to turn it over once torqued, as ideal clearance is .002.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
