Trying to locate Farmall H main bearing kit .002 undersized
Posted by Yooper Farmall on February 16, 2012 at 07:30:18 from (141.210.112.16):
Trying to boost oil pressure, had the oil pump cover machined then used plastiguage on the bearings, they have a clearence of about .004, took a couple bearings off to get the serial numbers, and found they are for a .002 undersized crank. I"ve found a rod bearing set but cannot find a main bearing set. Called IH and they said they are discontinued and cannot get their Tisco aftermarket bearings either. My H is a "41, serial is 79680, I see the early H"s take a different bearing than the late H"s. Trying to find .002 and not having to remove the crank and turn it.
