Re: Trying to locate Farmall H main bearing kit .002 und...
Posted by D Slater on February 16, 2012 at 12:08:22 from (184.15.43.207):
In Reply to: Trying to locate Farmall H main bearing kit .002 undersized posted by Yooper Farmall on February 16, 2012 at 07:30:18:
Depending on how much the .002 are worn webers shows a .003 main set if you want to take a chance. I would want to measure the crank carefuly before trying. Can't check the mains very good unless crank is removed though. May as well have it turned if removed unless it checks out. Doubt it well check okay unless it came new at .002.
