Re: Trying to locate Farmall H main bearing kit .002 und...
Posted by Yooper Farmall on February 16, 2012 at 13:44:33 from (141.210.112.16):
In Reply to: Re: Trying to locate Farmall H main bearing kit .002 und... posted by gene bender on February 16, 2012 at 13:15:03:
Right, the crank is smaller from wear therefore undersized, needing a thicker bearing. The crank is worn, therefor needing a thicker bearing with a smaller/undersized inner diameter. Might be a little counterintuitive referring to a thicker bearing as undersized, but we are referring to the inner diameter.
